Help identifying an older oliver industrial TLB - lots of pictures
   / Help identifying an older oliver industrial TLB - lots of pictures #1
fatjay
Veteran Member
Eastern PA
Not enough
Edit: I figured out it's a '55 Oliver 77 Industrial with Ware loader and backhoe. The 77 was really popular it seems and parts should be plentiful. 35hp 6 cylinder engine. No idea what hte hydro pump is making, there's no way it started out looking like that.
It's older but aside from the paint, is in good condition. 4 new tires all around, all cylinders in great shape with no leaks. There's some leaks in the rear spool valves, hopefully replacing the o-rings will fix that. There's a diverter valve on the resivior tank for front/rear hydraulics. Boom is a little slow, I suspect due to the valves.
I thought it was a 770, but now seeing it in person it's definitely not set up the same. It has a 6 cylinder gas motor, 6v starter. He had a 12v battery in, which I suspect is a little hard on it, but it fired up instantly. New points and new gas, sediment bowl was crystal clear so I suspect that was recently cleaned. No oil leaks from the engine. 6 speed manual transmission.
The backhoe is a Ware I'm told, but I don't know what model the actual tractor is. Any help on identifying and fixing the few problems it has would be greatly appreciated.
