Help Identifying a Spreader
/ Help Identifying a Spreader #1
llgetty
John Deere 4044R
Can anyone help me identify this spreader? My daughter-in-law brought it home and it worked for a short period of time then twisted a shaft on the upper set of teeth. Trying to see if parts are around. Thanks in advance. 20201202_141246.jpg
/ Help Identifying a Spreader #2
Show a photo of the break. You may have to repair or make a new one after you figure out WHY it broke.
/ Help Identifying a Spreader #3
Are the markings more prominent on the OTHER side?
/ Help Identifying a Spreader #4
Doesn't look familiar for spreaders in this area, but as good of shape as it appears to be, seems there ought to be a mfg. tag still intact somewhere on it. I'm seeing some cast in part numbers like on the top beater housing, and ratchet gear. Might get an idea by writing those part numbers down, then doing a search on Google, and see if anything comes up. Worth a shot.
I've found out what several pieces I have had in the past, with no markings that were ledgeable. by doing that.
Thank you Big Barn. I can barely make out the words Non Wrap on the side.
Now to see if we can find parts.
/ Help Identifying a Spreader #7
You're welcome. And good luck.
If nothing is available post photos of the broken piece. Some of the guys here will most likely have good ideas for a fix.
I can't figure out how to take this down but it is sold.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2011 Kia Sorento SUV (A64557)
2011 Kia Sorento...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
10in Bucket w/ Teeth Excavator Attachment (A64194)
10in Bucket w/...
Aluminum Mermaid (A65583)
Aluminum Mermaid...
Glencoe 20' Field Cultivator (A66408)
Glencoe 20' Field...
