Help Identify Char Lynn/Eaton Motor
   / Help Identify Char Lynn/Eaton Motor #1
blake in spokane
Heres all the #'s 4940 F04409 2254 112-1066-006
   / Help Identify Char Lynn/Eaton Motor #2
These are the specs. for a "similar" TRW from Baum Hydraulics catalog, so should be pretty close. 19.2 cu. inch displacement, 3500 PSI continuous, 4750 peak, 9105 constant torque, 11625 peak torque, 30 gpm constant flow, 35 gpm max flow. 1 1/2" shaft and a 4 bolt mount.
Kim
   / Help Identify Char Lynn/Eaton Motor #3
I was going to attach the actual specs but the file size is to large. Go to Eaton website and look for 6000 series Disc valve motors.
Kim's numbers are close.
NOTE: This website can be hard to navigate but the info is all there.
Roy
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
2010 L3V Electric cart (A51694)
2010 L3V Electric...
Hyster H225E Forklift (A47477)
Hyster H225E...
2018 MACK CHU613 PINNACLE DAY CAB (A53843)
2018 MACK CHU613...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
