Front-End Loader Help Identify a FE Loader
/ Help Identify a FE Loader #1
caverly
Vernon, BC
Ford 3000
Hello all,
I found a loader for sale on the side of the road the other day and I'm hoping to identify it and find out if I can mount it on my Ford 3000 gas.
Can anyone help? The only model indicator I can see is it says 394 on one side, the rest is long worn off.
Thanks,
Ken
front end loader 394 (1).jpgfront end loader 394 (2).jpgfront end loader 394 (3).jpgfront end loader 394 (4).jpg
/ Help Identify a FE Loader #2
Looks to be fairly HD, perhaps a bit much for you tractor but hard to say.
Eveballing it compared to the truck bed puts it about 48" wide so probably if you weld and are handy you might be able to adapt.
The bucket is 6' wide, it's 28" inside the frame where it would mount to the tractor. The C frame arms are 51" long.
A quick measurement of the tractor makes it look possible, but there may be interference with some of the steering arms/linkages.
Ken
/ Help Identify a FE Loader #4
Looks like Allied loader.
/ Help Identify a FE Loader #5
Heres a link to farm king allied loaders Request Rejected
You'll see they still offer a 395 loader possibly the replacement for the 394?? I searched the mounting kits and there are 2 listed for the 3000 Ford.
Was that loader in a fire? It has that look to it .
/ Help Identify a FE Loader #6
if it has been in a fire leave it be
Thomas - Spot on, it's an Allied 394.
Winmac - Thanks, I'll give Allied a shout and see if there's still mounting kits available and compatible.
Whis - Why do you say that, and how could I tell?
The guy's only asking $300, so it seems like even if it needs new hoses and maybe even cylinders it would still likely be a good buy.
Ken
/ Help Identify a FE Loader #8
If the loader has been through a fire you cannot rely on the strength of the steel. Should it fail under load it could kill you.
A fire is also likely to have warped dimensions so it will not work right.
/ Help Identify a FE Loader #9
Thank you all for your quick responses. you have convinced me to leave it right where it is.
Ken
Trailmobile Van Trailer (A63118)
Trailmobile Van...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2022 Ford F-150 Pickup Truck (A61568)
2022 Ford F-150...
KUBOTA MX4800 TRACTOR (A62130)
KUBOTA MX4800...
