Rotary Cutter Help: Ideas on how to remove a rotary cutter rotor
   / Help: Ideas on how to remove a rotary cutter rotor #1
stephan
NSW, Australia
Lamborghini 450 Runner, SAME Tiger 70, Kioti CS2610
Hi,
To cut a long story short I replaced the gearbox on the rotary cutter and tried to use the rotor as is. It mostly worked but was 1cm short from seating completely home even after bashing it enthusiastically with a sledge hammer. So now I need to take it off again before I use it and do it properly (don't want to risk the $680 gearbox). I'll get a pro to cut the old gearbox's female spline off and weld on the one that came with the new box but the problem is this:
Remember the bit about bashing it enthusiastically? Well it won't come off easily. This is where I need some idea's? I'll post some pictures tomorrow but for now....help?
Stephan.
   / Help: Ideas on how to remove a rotary cutter rotor #2
Can you heat the rotor with a A/C torch?
Can you wedge something between the hub and ??? to force it out?
Can you place a gear puller on it, and then beat it a little?
My only suggestions without a pic.
ron
Ahh brilliant. I bought a gear puller and tapped the spline while tightening the puller and it just came off.
Thanks.
   / Help: Ideas on how to remove a rotary cutter rotor #4
ALRIGHT!
   / Help: Ideas on how to remove a rotary cutter rotor #5
Always great to see a simple but clever idea solve a problem efficiently and completely. Well done guys.
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2016 Ford F-250 4x4 Reading Service Truck (A55852)
2016 Ford F-250...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A53424)
70pc. 12ft.x 3ft...
2016 Ford Expedition SUV (A55853)
2016 Ford...
John Deere 6120E (A50323)
John Deere 6120E...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
