Rotary Cutter Help: Ideas on how to remove a rotary cutter rotor
   / Help: Ideas on how to remove a rotary cutter rotor #1
stephan
NSW, Australia
Lamborghini 450 Runner, SAME Tiger 70, Kioti CS2610
Hi,
To cut a long story short I replaced the gearbox on the rotary cutter and tried to use the rotor as is. It mostly worked but was 1cm short from seating completely home even after bashing it enthusiastically with a sledge hammer. So now I need to take it off again before I use it and do it properly (don't want to risk the $680 gearbox). I'll get a pro to cut the old gearbox's female spline off and weld on the one that came with the new box but the problem is this:
Remember the bit about bashing it enthusiastically? Well it won't come off easily. This is where I need some idea's? I'll post some pictures tomorrow but for now....help?
Stephan.
   / Help: Ideas on how to remove a rotary cutter rotor #2
Can you heat the rotor with a A/C torch?
Can you wedge something between the hub and ??? to force it out?
Can you place a gear puller on it, and then beat it a little?
My only suggestions without a pic.
ron
Ahh brilliant. I bought a gear puller and tapped the spline while tightening the puller and it just came off.
Thanks.
   / Help: Ideas on how to remove a rotary cutter rotor #4
ALRIGHT!
   / Help: Ideas on how to remove a rotary cutter rotor #5
Always great to see a simple but clever idea solve a problem efficiently and completely. Well done guys.
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2012 Ford Focus Hatchback (A48082)
2012 Ford Focus...
2023 Ford Explorer AWD SUV (A48082)
2023 Ford Explorer...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2005 Utility Trailer FS2CDHA 18 Ton T/A Flatbed Trailer (A48081)
2005 Utility...
