Help ID this mystery tiller
   / Help ID this mystery tiller #1
Littlecedarfarm
Yanmar 155d
Hi All, wondering if someone can help ID this tiller and more importantly assist a newbie attaching to 3 point on my Yanmar 155D tractor. I’m confused because it doesn’t look like it has a top link connection... any help would be amazing.
   / Help ID this mystery tiller #2
It's a Kubota tiller made for the B7000, B7001, etc series. It uses a proprietary 2 point mount with the short PTO shaft in the middle.
It's actually missing the original lift arms.
You can't use it as is on your Yanmar. It will need modifications and a new PTO shaft. Basically needs a triangle to provide the two bottom pins and top pin for the 3 pt hitch of your tractor.
   / Help ID this mystery tiller #3
Here is an example of one hooked to the tractor. Sorry, one came out sideways.
Your tiller is actually the first one I see with the middle mounted drop box. Most Kubota tillers had the side mounte drop box with the chain transmiting power to the rotor.
image;s=1000x700
image;s=1000x700
Thank you! I was thinking of trying to find some shorter lift arms and a pto shaft extender as a modification
   / Help ID this mystery tiller #5
Think you will find that there is a rear wheel that can be adjusted for height. There is no top link.
The bottom arms are attached to the tiller. The lift arms are not attached to bottom arms but rather to the tiller. This makes a type of three point connection.
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
Cat Mixer RM-250C (A55973)
Cat Mixer RM-250C...
Enmark Z Spray (A53316)
Enmark Z Spray...
