Help! I am new... Do I have a Ford 1210? or 1100?
   / Help! I am new... Do I have a Ford 1210? or 1100? #1
mvpvideo
Chapel Hill
Ford 1100
Help! Need pinion gear... Do I have a Ford 1210? or 1100? Photos attached
I have a Ford 4x4 compact tractor with the 1210 decal on the hood, but it only has two cylinders...? Also, on the engine block is stamped LEH 822. I have searched everywhere for a Shibaura LEH 822 engine spec. I think I have a different Ford model than a 1210 because of the engine. Does anyone know what Ford tractors had a Shibaura LEH 822 engine in them???
To further complicate matters, the serial number is unreadable on the metal plate!
Thanks so much for any info!
John
Attached are photos... what I am trying to find is a pinion gear... but I don't know which model I have!!!
   / Help! I am new... Do I have a Ford 1210? or 1100? #2
I don't recall ANY Ford CUT with a decompression device.
Can you say 'grey market'?
   / Help! I am new... Do I have a Ford 1210? or 1100? #3
Welcome from Wisconsin
I'm not sure what you mean? What does cut with a decompression device mean? Do you think my tractor is a grey market tractor?
   / Help! I am new... Do I have a Ford 1210? or 1100? #5
I am only guessing here, but I think "CUT" is short for Compact Utility Tractor. I think what he is sayiny he hasn't seen any Ford with the valve cover (head) like your picture that has some kind of compression relief built into it. Rick will clear that up for you;
Another guess by me (because I don't know) is your engine is non typical and you may have a 1200 off brand engine, 2 cyl, in a 1210 tractor body. That engine is probably made by the same manufacture for a different brand tractor or a special duty tractor designed for extreme service, like a cold climate of something.
I think your tractor is a 1210 as far as everything but the engine is concerned and parts for the 1210 would fit your repairs. But wait for more information from other posters because this is only my guess from viewing the hood picture.
Shibaura did and probably still make some tractor engines for Ford.
   / Help! I am new... Do I have a Ford 1210? or 1100? #6
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2016 GMC YUKON SLE (A58375)
2016 GMC YUKON SLE...
FORD 4600 TRACTOR (A58375)
FORD 4600 TRACTOR...
Year: 2003 Make: Land Rover Model: Discovery Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A59231)
Year: 2003 Make...
1981 FRUEHAUF CRUDE OIL TRAILER (A58214)
1981 FRUEHAUF...
