Help! Hydraulics are slow
   / Help! Hydraulics are slow #1
MarcusCarr
Idaho
Kioti DK35
I have a Kumaia ST 2040, which is identical to a Mitsubishi D2050FD. I have a feeling that I may have blown my hydraulic pump. Here are the symptoms that occur to the FEL hydraulics and the 3 point lift.
At 2000 RPM, none of the hydraulics work.
At 2500 RPM, the hydraulics are very slow to respond but appear to have their full strength. I pushed the FEL all the way down and it eventually lifted the front of the tractor.
I know that the quick connects have popped apart twice while I have owned the tractor, so I am guessing I deadheaded the pump and blew it up.
Is there a sheer pin in these pumps?
Can I rebuild one myself?
How can I be certain that the problem is really a bad pump?
If a part of the pump was ruined by deadheading the system, what part needs to be replaced?
I fould a replacement pump for $360, but I would much rather repair the problem than throw a whole new pump at it.
Thank you for your help,
Marcus
   / Help! Hydraulics are slow #2
DO you have any access to a FLow meter? Sounds like you have pressure but no flow. That certainly indicates a pump issue. $360 for the pump really didn't sound bad to me... I would have guessed much worse, but I have no knowledge about those units either. Does the tractor pump have a relief? That should help the deadhead issue...
I moved this post to the repair section
Marcus
JOHN DEERE 560M LOT NUMBER 129 (A53084)
JOHN DEERE 560M...
2013 Caterpillar 950K Articulated Wheel Loader (A51691)
2013 Caterpillar...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2003 Wells Cargo CVG3225 5th Wheel Office Trailer (A53117)
2003 Wells Cargo...
