> HELP< Hydraulic 3 point hitch
   / > HELP< Hydraulic 3 point hitch #1
Doug Barchard
CHILLIWACK B.C. Canada
CASE 310
Help ! Sombody must know about the workings of 3 pnt. hitch, as they seem to be the same on all the early models of tractors.Like in the 1950's and 60's
Here is my problem, The lift arms usually go up and down with the movemrnt of the lever just below your seat on right side. My lift arms are up as high as they go, and will not come down no matter where we move the lever. We also tried loading 500 pounds on , but no movement. The previous owner said they were going up and down, two months ago.
>>>>> Help where do I start ???
   / > HELP< Hydraulic 3 point hitch #2
Not sure but there could be a knob or some adjustment to regulated the level of the arms dropping.
It can also be truned tight to keep it from dropping at all. I know on most tractors its by the seat front middle.
It might be called The Hydraulic speed control this link might explain it better
http://www.tractorforum.com/f202/hyd-lift-problem-9753/
Im sure the others will want to know the year and or model..
   / > HELP< Hydraulic 3 point hitch #3
I agree. I believe that knob will lock the arms in any position. Turn left to loosed and see if they will drop.
   / > HELP< Hydraulic 3 point hitch #4
Do you know the make and model by chance???? sure they are all the same idea but many different ways to do the same thing. rate of drop valve is the first thing to check though .
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2016 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2016 Ram 1500 4x4...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
500BBL WHEELED FRAC TANK (A50854)
500BBL WHEELED...
