Help hooking up post driver
/ Help hooking up post driver #1
wayupnth
Maine
I am looking for some tips/ideas to hook up a post driver. The unit requires a hydraulic feed into a single action piston. The return goes directly into the reservoir. The return of fluid needs a very low resistance path or the fluid gets too hot. I am using a JD 4520 which has a direct connection to the hydraulic reservoir for the backhoe so I am all set there.
For an infeed, I have a power beyond and a 3rd SCV piped to the rear of my tractor. I have a hydraulic top tilt hooked to the 3rd SCV so I can adjust the post driver's angle on slopes. If I unplug the power beyond for an infeed to the post driver, since the return is into the reservoir, the 3pt hitch doesn't work so I can't use lift the driver to move it to the next post.
JD makes an electronic diverter to use the loader joystick as a 4th and 5th SCV but I didn't really want to spend the $1200 plus installation for an intermittent use. I wasn't sure if I could use a mechanical selector valve to divert flow from either the power beyond (not sure if this is a good idea) or the 3rd SCV into the post driver. I think that would work although it still would require some work. I don't think there is an easy answer but I am open to suggestions.
Gary
/ Help hooking up post driver #2
I would use either a manual or electric diverter to select either the top tilt or driver lift circuit. You have no need to use both simultaneously. $1200 for an electric diverter is absurd, they are available for about a third of that; or less. I would not use the power beyond circuit, as the hitch is disabled whan the PB is in use.
2016 CHEVROLET TAHOE (A66091)
2016 CHEVROLET...
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
2009 CHEVROLET IMPALA (A66091)
2009 CHEVROLET...
2013 GMC Seirra 2500HD Ext. Cab Knapheide Service Truck (A68183)
2013 GMC Seirra...
PALLET OF HOSE FITTINGS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF HOSE...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
