Help hooking up post driver
   / Help hooking up post driver #1
wayupnth
Maine
I am looking for some tips/ideas to hook up a post driver. The unit requires a hydraulic feed into a single action piston. The return goes directly into the reservoir. The return of fluid needs a very low resistance path or the fluid gets too hot. I am using a JD 4520 which has a direct connection to the hydraulic reservoir for the backhoe so I am all set there.
For an infeed, I have a power beyond and a 3rd SCV piped to the rear of my tractor. I have a hydraulic top tilt hooked to the 3rd SCV so I can adjust the post driver's angle on slopes. If I unplug the power beyond for an infeed to the post driver, since the return is into the reservoir, the 3pt hitch doesn't work so I can't use lift the driver to move it to the next post.
JD makes an electronic diverter to use the loader joystick as a 4th and 5th SCV but I didn't really want to spend the $1200 plus installation for an intermittent use. I wasn't sure if I could use a mechanical selector valve to divert flow from either the power beyond (not sure if this is a good idea) or the 3rd SCV into the post driver. I think that would work although it still would require some work. I don't think there is an easy answer but I am open to suggestions.
Gary
   / Help hooking up post driver #2
I would use either a manual or electric diverter to select either the top tilt or driver lift circuit. You have no need to use both simultaneously. $1200 for an electric diverter is absurd, they are available for about a third of that; or less. I would not use the power beyond circuit, as the hitch is disabled whan the PB is in use.
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
