HELP HELP WITH A BROKE BUSH HOG
   / HELP HELP WITH A BROKE BUSH HOG #21
just don't forget that $5 worth of paint can really increase your sell price.
Gearbox outputshaft cost and seals will cost more that worth to fix and new gearbox complete will run $400+ and your blade carrier may not fit at that--so I Would run it until it quits and then buy a new brush hog from Sweet Farm Equipment in Ky--I think they have a website and ship nationwide?--If memory serves me correctly? New HD 6 ft around $700 or less
Now... remember way back, being a teenager... spending a thousand or two to keep that $100. car... a running... /w3tcompact/icons/wink.gif
   / HELP HELP WITH A BROKE BUSH HOG #24
Drill and tap a grease zerk into the box and fill it with gun grease. It will last for years like that. You can put it in the fill plug. Pump grease into it until it comes out the leaking seal. I'd grease it every couple of hours until I figured out how long an interval I could get away with.
   / HELP HELP WITH A BROKE BUSH HOG #25
But would you be as mechanically inclined today if you had had a $10,000 car and only spent $100 to keep it running?/w3tcompact/icons/smile.gif
Jeff
   / HELP HELP WITH A BROKE BUSH HOG #26
When I get to this point I dump in 1 or 2 cans of a STP knock-off along with the grease because of "cavitation" within the gearbox with grease alone.
<font color=blue>...only spent $100 to keep it running?...</font color=blue>
Tell me quick... which car is that cheap to keep running... I'll buy it... /w3tcompact/icons/smile.gif
   / HELP HELP WITH A BROKE BUSH HOG #28
I think you are doing the right thing by getting rid of it. I would NOT want to runn that hog with a blade spinning and not have it supported with the correct bearings on both the top and bottom of the output shaft. What happens when that gear box lets go and the blade comes screaming out from under the cutter /w3tcompact/icons/shocked.gif. I'm sure something else will come along.
   / HELP HELP WITH A BROKE BUSH HOG #29
That was repairs only...not maintenance..../w3tcompact/icons/frown.gif
Jeff
Freighliner Tender Truck (A55315)
Freighliner Tender...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Utility Trailer (A52377)
Utility Trailer...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
66'' root grapple (A53421)
66'' root grapple...
