HELP HELP WITH A BROKE BUSH HOG
   / HELP HELP WITH A BROKE BUSH HOG
The bad seal that you have was probably caused by whoever welded the nut onto the shaft. (they got the shaft too hot and burned up the seal.) I would also tend to think that the threads on the shaft must be stripped or whoever welded that nut on would have just tacked it on instead. But then how would they hold the nut on tight enough without threads to hold it down... Maybe there are enough threads left...
Maybe you could just weld up a franken-cutter and forget about the bad seal and use it like it is. Although it might drip grease out onto your pasture if you leave it like it is.
   / HELP HELP WITH A BROKE BUSH HOG #12
beenthere: I too have had some luck doing what you are referring to but in this case I just don't think it will work. If you could see it I think you would agree. It looks like they had their welder cranked up to maximum heat and the nut and the shaft is fused into one big ugly glob.
kubotadriver: If the top were not in such bad shape I would probably try to use it as is. I have run chassis grease in leaking cutters before and never burned one up - just shoot it full of grease every 8 hours or so. My fear on this one is that the top cannot support the gearbox and the vibration of the blades. It is gone.
you can't just weld straight to the gearbox with some plate steel? That would make it useable at least.
p.s. I have pretty much sworn off auctions and pawn shops for reasons such as this. Hidden problems that drive the price of an object up to nearly the price of a new one.
Back to your problem, I think that it would be a bad idea to try to rig that shaft with some funky engineering. I think you are on the right track to get a new shaft. If that blade holder were to go flying off of there at full speed the FAA might get UFO reports from over 100 miles away!
   / HELP HELP WITH A BROKE BUSH HOG #14
kubotadriver,
I think You are right sometimes you have to step back take a deep breath and decide if the project is worth it. I was thinking about those antique tractor restorations where you end up putting about twice as much into it as the finished tractor is worth even if it really is nice.
Chris
   / HELP HELP WITH A BROKE BUSH HOG #15
OMNI Rotary Cutter Gearbox
Part No. 401-0171 $245.00 Wt. 50.52 lbs.
Desc. GEARBOX, 35HP SC OMNI 250002
Details: 35 hp, 1:1.47 ratio, 1 3/8 6 spline input, 12 spline output, 4 bolt mounting, 6 3/4 diameter bolt hole mounting circle, hub 401-7559 shown for reference only order separately
All Manufacturer's Names: Alamo Group, BMB, Bushwacker, Dale Phillips,
Darrell Harp (Big Bee), Ford, Harp, Hico, King, Modern,
Mohawk, Rhino, Servis, Sidewinder, Terrain, Terrain King,
United Farm Tools (Mohawk), J-Bar, King Kutter
Assembly Parts
501-0023 HOUSING, GR BX MAIN 1 $ 194.43
501-0024 SPACER, O/P 30HP 090000 1 $ 19.40
501-0021 SNAP RING, 30HP 200000 1 $ 1.93
501-0022 O/P SHAFT 15th 12SPL 030002 1 $ 129.00
501-0011 BALL BEARING REAR I/P 207K 1 $ 9.84
501-0036 SHAFT INPUT S/C 35HP 040003 1 $ 129.04
501-0030 PLUG, UPPER, NPT 1 $ 2.42
501-0014 GEAR,I/P 22TH 030003 1 $ 97.02
501-0016 GASKET,I/P SHIM 070002 4 $ 2.42
501-0015 SNAP RING, INPUT GEAR 1 $ 1.28
501-0020 SEAL 1 $ 4.85
501-0019 INPUT CAP 020002 1 $ 49.22
501-0018 BOLT, 3/8x1 HH NC 1 $ .55
501-0017 LOCKWASHER, 3/8 1 $ .49
501-0025 BALL BEARING 3 $ 10.50
501-0026 GASKET,OUTPUT 070001 4 $ 2.42
501-0028 LOWER BEARGING RETAINER 020003 1 $ 51.49
501-0027 SEAL 1 $ 5.13
401-7559 GEARBOX HUB SM 12SPL 210000 1 $ 40.47
401-7471 FLATWASHER 1 1 $ 4.41
401-7263 CASTLE NUT 1 $ 6.22
900-8951 COTTER PIN 3/16x21/4 1 $ .28
501-0035 PLUG, LOWER, 1/8 NPT 1 $ 1.87
   / HELP HELP WITH A BROKE BUSH HOG #16
OMNI Parts Breakdown
Ref. Part No. Part Description Comments
10 826-035C GEARBOX RC71SS 1:1.46 INCREASE
10
1. 020162 OMNI INPUT CAP
2. 070142 OMNI GASKET 0.10MM
3. 070141 OMNI GASKET 0.15MM
4. 070140 OMNI GASKET 0.30MM
5. 050013 OMNI BEARING CUP - LM 603014
6. 050012 OMNI BEARING CONE -LM603049
7. 040135 OMNI INPUT SHAFT
8. 030040 INPUT GEAR - 17 T., OMNI
9. 200003 OMNI RETAINING RING
10. 010112 OMNI HOUSING
11. 140033 OMNI PLUG VENT 1/2"
12. 140017 OMNI PLUG PIPE SQ HEAD 1/8"
13. 030041 OUTPUT PINION - 14 T., OMNI
14. 090073 OMNI SHIM .25
15. 050008 OMNI BEARING CONE - 368
16. Ä À Ë 050014 BEARING CUP - 362A, OMNI (S/N 107994+)
16 Ê 050015 BEARING CUP - 362, OMNI (S/N 107993-)
17. 040112 OUTPUT SHAFT, OMNI
18. 070145 OMNI GASKET 0.10MM
19. 070144 OMNI GASKET 0.15MM
20. 070143 OMNI GASKET 0.30MM
21. 060004 OMNI OUTPUT SEAL
22. 020005 OMNI OUTPUT CAP
23. 090055 SPACER, OMNI
24. 803-095C NUT HEX SLOTTED 1-14
25. 805-017C PIN COTTER 3/16 X 1 3/4 PLT
26. 802-091C HHCS 1/2-13X1 1/2 GR5
27. 804-015C WASHER LOCK SPRING 1/2 PLT
28. 802-079C HHCS 3/8-16X1 1/4 GR5
29. 804-013C WASHER LOCK SPRING 3/8 PLT
30. 060005 INPUT SEAL, OMNI
31. 050015 BEARING CUP - 362, OMNI
32. 804-070C FLAT WASHER 1 SPECIAL
33. 090055 SPACER, OMNI
IMPORTANT: When ordering gearbox parts, be sure to have the I.D. tag number off the gearbox and the serial
number off of the cutter. This is important in knowing which gearbox your cutter has.
   / HELP HELP WITH A BROKE BUSH HOG #17
JM3,
You never cease to amaze me. Where you come up with this technical info and drawings I'll never know. This gives me an idea of what I'm getting into at least. Now if I can figure out if it is an OMNI or whatever it is.
I talked to the guy at the auction house and he told me to bring it back down there (it's only about 15 minutes away) and they would run it back through the first Saturday of April. He thought I would recoup most of my money. Unless I can positively identify the mfgt. of the gearbox I think that's what I'll do.
THANKS TO ALL FOR THE HELP!!!
TBone
   / HELP HELP WITH A BROKE BUSH HOG #18
Great - the auctioneer tells you to bring it back, and he gets paid each time he sells it. Sounds like stockbrokers.
   / HELP HELP WITH A BROKE BUSH HOG #19
Yeah, I agree. The auctioneer is the only one making money on this deal. I had (almost) $130. worth of fun with it anyway.
TBone
   / HELP HELP WITH A BROKE BUSH HOG #20
Maybe you can buy it even cheaper the next time./w3tcompact/icons/wink.gif
20701 (A55853)
20701 (A55853)
Miles read : 112,969 (A50323)
Miles read ...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
