Help !!! Fire Ants !!!
   / Help !!! Fire Ants !!! #52
I spray 3/10 oz per acre of Regent. I spray about 10 acres and haven't seen a fire ant on the whole place in 12 years. If I spray a 1/2 oz i can skip a year maybe 2.
   / Help !!! Fire Ants !!! #53
Since they can't take the cold I tried digging into a mound when it was freezing temps to see if that would kill them.
Didn't work, the mound like is concrete. I might try it again now that I have a stump bucket for the tractor.
I would love to freeze them to death as payback.
   / Help !!! Fire Ants !!! #54
poor gas on the nest but don’t light it up the fumes will kill them
Pour a 50/50 mix of diesel and gas down the mound, then light it. The oily diesel keeps the fuel from flashing up all at once, then burning out fast. The mix will burn slower and for a longer period of time. And it will just burn, not explosively flash up when you light it, so it’s much safer to use.
   / Help !!! Fire Ants !!! #55
yes i have done that but it seem like not light it up at all works even better … the fire is superficial above the nest surface since it need oxygen to burn … burning pulls the fume away … not burning it keeps the fumes in longer
   / Help !!! Fire Ants !!! #56
We don't have any fire ants around here. I always thought it was because we were far enough north. I'm surprised there would be any in northern Ontario.
   / Help !!! Fire Ants !!! #57
I don’t have them either at my 6800’ elevation. But I have used the same technique to get rid of native ants making mounds near buildings.
   / Help !!! Fire Ants !!! #58
I don't know if we do, probably not, we do have red ants that bites whether or not they are part of the genus Solenopsis I don't know but probably not... but fire ants or not, none are immune to gas fumes...
   / Help !!! Fire Ants !!! #59
I still have an old bag of Diazanon. Thin ring around the ant hill does the trick.
   / Help !!! Fire Ants !!! #60
From what I understand about fire ants, you have to kill the queen to destroy the colony. Just killing a bunch of ants accomplishes nothing. Same thing with termites.
I personally like Orthene from the box stores. https://www.lowes.com/pd/ORTHO-Orthene-12-oz-Fire-Ant-Killer/5013597781
It's a very fine white powder that you just barely sprinkle on the mound. They say the best time is early morning or late evening, when the ants are most active. But it really doesn't seem to matter when you do it, the mound is always dead the next day. The biggest issue with Orthene is the smell. It's horrible!!!!
Usually I do my walk through the yard the day after I mow it. I just deal with areas that I keep mowed. When I see a mound forming, I sprinkle a little Orthene it and it's done. The bright white color of the powder makes it easy to see what mounds I've treated and what mounds are new. Usually in the Spring, there are a lot of them, but by Summer, there will only be a few of them. By the end of Summer, it's rare to see any new mounds.
My wife is finishing up the Master Gardener program with Texas A&M, and they recommend sprinkling Diatomaceous Earth on the mounds. I haven't done that yet, but plan on giving it a try in the Spring when the mounds start to show up.
When I've been bit by fire ants, I've found that for me, Hand Sanitizer works great. I think the alcohol dries out the bite, and that stops the inflammation. I used it during Covid because that's all I had at the time, and I was surprised by the results.
1405 (A58374)
1405 (A58374)
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
Suzuki Vision Quad Runner 500 (A55272)
Suzuki Vision Quad...
6" X 1" X 10' FLAT IRON 4-STICKS (A58374)
6" X 1" X 10' FLAT...
2018 JLG 600S TELESCOPIC BOOM LIFT (A52709)
2018 JLG 600S...
