help finding KL401 loader bushings
/ help finding KL401 loader bushings #1
blurry
Auburn, ny
DK40SEH
Looks like I have a fair amount of play on the bushings for the KL401 loader on my DK40SEH after only 350 hours. I grease them at least once a month, apparently that didn't help much. looks like the loader has a 1 year warranty. Could someone help me locate where to get the parts?
thanks!
well, I found them - $734 for new bushings seems a bit steep, am I missing something?
Pivot Pin, 30mm x 100mm
M3245-11751
Pivot Pin, 30mm x 100mm at $48.95
$195.80
Remove Item
Pivot Pin, 30mm x 125mm
M3245-11741
Pivot Pin, 30mm x 125mm at $69.51
$278.04
Remove Item
Pivot pin, 30mm x 121mm
M3245-11722
Pivot pin, 30mm x 121mm at $66.16
$264.64
Remove Item
/ help finding KL401 loader bushings #3
I'm assuming you mean $734 for new pins, not bushings? For new stock pins all around that price seems typical, But having them wear out at 350 hours is very strange, So pins are not something one buys very often. I use my loader frequently, with more hours, and the pins show no wear at all. I haven't looked at my bushings, not sure they can even be punched out or replaced. May have to be a bore and insert job.
Keep in mind, they have a small amount of play as per design. But perhaps yours has gotten much worse?
Can you send us photo of a pin, and a bushing of yours that is worn?
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
YALE FORKLIFT (A63291)
1991 Wilson Hopper Bottom Trailer (A66285)
1991 Wilson Hopper...
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
