Help filling Davis 100 loader pls
   / Help filling Davis 100 loader pls #1
Donben1
Cochrane, ab
Case930, Kubota b5100e
Hello,
I recently purchased an old Ford 8N with a Davis 100 loader. Im new to tractors but was able to get the loader installed on the tractor. I had to get the front pulley machined and a new shaft put on as old one was wore out. It was surprising easy to split tractor to change the pulley and install new one! I found out after the expensive machining that the "just 8n's" website had all the parts brand new errr, next time. I was able to put another rubber connector (spider gear?) in middle to help take out and play and/or vibration...works awesome. I can also take loader off if needed and split shaft just outside front with only about an inch and 1/2 sticking out of tractor, would be totally behind grill so no accidents with a turning shaft out there.
The loader has had a very slow leak out of the front seal of pump (I'll remove and fix once snow stops) . I would like to top up the fluid but not sure where or how much to put in. I ordered a manual off ebay but it wont be here for a week or two and would like to top it up now. I bought hydraulic fluid at Canadian Tire that's says suitable for farm equipement accessories. I'm assuming I can pour it down the vent tube if I remove the cap but I don't know how much to ad?? Is it ok to mix this fluid with whatever the last owner put in?
Thank you!!
Donovan
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
(15) 6" X 2" X 41" TUBING (A54756)
(15) 6" X 2" X 41"...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2019 Ford F-550 4x4 Altec AT40G 40ft Bucket Truck (A55788)
2019 Ford F-550...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
