Help filling Davis 100 loader pls
   / Help filling Davis 100 loader pls #1
Donben1
Cochrane, ab
Case930, Kubota b5100e
Hello,
I recently purchased an old Ford 8N with a Davis 100 loader. Im new to tractors but was able to get the loader installed on the tractor. I had to get the front pulley machined and a new shaft put on as old one was wore out. It was surprising easy to split tractor to change the pulley and install new one! I found out after the expensive machining that the "just 8n's" website had all the parts brand new errr, next time. I was able to put another rubber connector (spider gear?) in middle to help take out and play and/or vibration...works awesome. I can also take loader off if needed and split shaft just outside front with only about an inch and 1/2 sticking out of tractor, would be totally behind grill so no accidents with a turning shaft out there.
The loader has had a very slow leak out of the front seal of pump (I'll remove and fix once snow stops) . I would like to top up the fluid but not sure where or how much to put in. I ordered a manual off ebay but it wont be here for a week or two and would like to top it up now. I bought hydraulic fluid at Canadian Tire that's says suitable for farm equipement accessories. I'm assuming I can pour it down the vent tube if I remove the cap but I don't know how much to ad?? Is it ok to mix this fluid with whatever the last owner put in?
Thank you!!
Donovan
2018 CHEVROLET TAHOE SUV (A54607)
2018 CHEVROLET...
2018 SOLAR TECH SILENT MESSAGE / LIGHT BOARD (A52705)
2018 SOLAR TECH...
2010 Ford Fusion Sedan (A55758)
2010 Ford Fusion...
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
2015 Ford F-350 4x4 Pickup Truck (A55852)
2015 Ford F-350...
2006 FORD F-350 (A53422)
2006 FORD F-350...
