Help! - fan belt broke and BX24 overheated
   / Help! - fan belt broke and BX24 overheated #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
I did not notice the gauge. Saw a little smoke and the temp needle was in the red. I shut the motor off...what else should I do? The reservoir cap was open and it looks like most of the coolant is gone. Should I put some in and run the motor or should I let it cool down first?
   / Help! - fan belt broke and BX24 overheated #2
If belt is broke just let it cool while you get a new on. Running w broken belt would not circulate...bad with fluid added to a hot engine. dont worry, the engine is ok.
larry
   / Help! - fan belt broke and BX24 overheated #3
I would replace the engine.
On second thought, replace the belt, fill with water/antifreeze, run it for another 20 years. Try that then post back... :D :D ;)
   / Help! - fan belt broke and BX24 overheated #4
Had the same thing happen to me with my BX-23. Didn't notice the temp gauge but the smoke finally got my attention. I just shut her down and cooled off then eased her back to the garage later. Put a new fan belt on the next day and refilled the antifreeze. That was last fall with no issues since. You'll be fine.
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52128)
2021 John Deere...
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
Walking Floor Trailer 43ft (A50322)
Walking Floor...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
