Help - Extreme Nubie Flux Core
   / Help - Extreme Nubie Flux Core #1
Spike56
Platinum Member
Lexington, Texas
JD 2355
Hi all, Could use some Very Basic advice. Purchased a Miller 142 (not even setup yet) and want to practice with Flux Core. Two things I am uncertain about:
1.) When you load the wire, I see mention on U-Tube the machine will go into "jog" mode to help feed the wire. Once the wire is out the tip, how best to adjust the drive-roll tension ? Guess when you do this, the wire is "hot" as you pull the trigger ? I have 030 Lincoln wire.
2.) For practice, I need to purchase some flat steel to run beads on. Any suggestions on thickness of metal or does this matter ?
I doubt seriously I will ever get gas for welding, just a hobby. :)
   / Help - Extreme Nubie Flux Core #2
The wire will only hot when you actuate the trigger but not when you are jogging the wire out. Gee, I didn't realize they made flux core that small!
   / Help - Extreme Nubie Flux Core #4
According to the specs, you'll be able to weld up to 3/16" mild steel. Whoo-Hoo! I suggest you buy 1/8 mild steel to run beads on. Do not buy the zinc plated stuff or you'll make yourself sick.
Stop watching YouTube until after you've read the manual. Then you'll see what BS they have to say. ;)
   / Help - Extreme Nubie Flux Core #5
I've never heard of a flux core or mig machine that had a "non-hot" mode for feeding wire. Not sure why they would do that. So yes, it's probably hot when "jogging" (I've not heard that term either) the wire out. For drive roller pressure, refer to page 21 of the manual provided by @JimRB and and that (hopefully) came with your welder. For steel, purchase what you need for whatever project you'd like to do first, just get a bit extra. Obviously the first project should not be a highly critical part. Don't try to build a dump bed or a hitch to start with. Find some scrap steel to practice on. Old lawn mowers are often readily available for free.
   / Help - Extreme Nubie Flux Core #6
I think the wire is hot while on jog for loading wire. The idea is just super fast wire feed speed to hurry up the loading of the gun. Usually the jog stops just before the wire comes out so you often have to trigger again to finish. Often it's best to remove the contact tip prior to feeding through the gun. At least that's what I do.
   / Help - Extreme Nubie Flux Core #7
Never heard of JOG, but then again I use a Hobart and that term is not in any instructions.... Wire is alway HOT when trigger pulled..... Wire feed tension setting should be in manual.... Without welders manual you are just spitting into the wind.....And be sure you have polarity correct for FCAW..... And for metal to weld on, for practice any CLEAN "scrap" that is not galvanized should do, after all you are just learning.....
Funny statement that you will probably "never use gas"... After dealing with sloppy FCAW I went to GAS/Solid Core Wire (GMAW) almost exclusively, think I still have introductory partial roll of FC in a bin somewhere....
See getting started video here in "RESOURCES" ...
Think you are just beginning on your learning curve....Be aware there is a lot of good on Youtube and there is a lot of BAD that should be ignored..... Best to learn from local person who has your best interest in mind.....
   / Help - Extreme Nubie Flux Core #8
Notes for a newbie starting out, from a flux core 20 year amateur:
For flux core you need the type of drive wheel with 'teeth' in the groove (because the hollow wire is easily crushed with too much pressure), and the proper size wheel, the size is stamped on it.
Avoid the beginner mistake of too much clamp pressure at the feed wheel. From the owner's manual for another welder: You have enough clamp pressure if a 4" extension of wire will bend when you aim it down at a piece of wood. And from experience: any more clamp pressure than needed can distort the wire so it won't feed out of the contact tip.
Be careful when you unwrap the new spool of wire. It will want to unwind and make a birds nest. Get the wire installed with the spool brake rather tight, then loosen just to the point where the wire will sag a little when you let go of the trigger.
People who do pretty welds scorn flux core, its smoky while welding and flings tiny beads of metal near the welded bead so it requires more cleanup. But with experience, the quality of the weld is the same. It is widely used where you can't weld indoors with ideal conditions.
Lesson 2: Watch the puddle, not the arc.
Lesson 3: Practicing on scrap you will soon see that welding dirty metal causes uneven beads, with porosity and maybe skips. So grind to clean metal before welding. And bevel so that the weld goes into a V, where this is practical.
Lincoln wire is top quality but if you are buying small 4" spools it costs twice as much because there's only one lb on the spool, everyone else has 2 lb on that size spool.
I think you're going to enjoy learning welding.
   / Help - Extreme Nubie Flux Core #10
I just looked on Amazon. $1,150.
For a 50 lb 110v MIG welder.
That's over 10x more than the cheapest equivalent.
Did you win the lottery? That's real top quality pro grade equipment, while for just amateur puttering around I think something similar on Amazon around $200 will do flux core nearly as well. And weigh under 20 lbs. And have dual-voltage to get the maximum out of it.
I wish I were rich like that! :)
2025 78in Dual Cylinder Grapple Rake Skid Steer Attachment (A49346)
2025 78in Dual...
2008 KENWORTH W900 DAYCAB ROAD TRACTOR (A50459)
2008 KENWORTH W900...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 JLG G12-55A TELESCOPIC FORKLIFT (A50458)
2015 JLG G12-55A...
2015 Linde Diesel Forklift (A49346)
2015 Linde Diesel...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A48836)
2006 Volvo VNM...
