Help - Engine oil in the transmission!
   / Help - Engine oil in the transmission! #1
mccadders
Windsor, Ontario
Kioti LK3054
I'm new to owning a tractor and I've made a real noob mistake! I have a mid-nighties, I believe from the serial number search, Kioti LK3054. I recently added Engine oil to what I now understand to be the transmission fluid cap. The cap is between your feet. The sight glass ended up blowing out completely but a friend in the know managed to reseat it after losing a good amount of fluid.
My question is should I be ok just using a transmission fluid flush agent, run for a 15mins through the gears in idle, then drain the transmission fluid from the pan and refill? I did read on another post that the transmission needs 27.5 quarts of fluid to refill. As I don't have the manual any suggestions on brands or specs to use on the refill?
Thanks in advance,
   / Help - Engine oil in the transmission! #2
How much oil did you add? Engine oil diluted in 27.5 quarts of trans. fluid may not have any negative effect if a small amount.
Thanks for the response Dave. When I saw what I thought was the oil level in the sight glass I put 3liters in, but then it blew the sight glass out when my buddy was clearing the snow. Since then I put 2 back in without realising that I was doing it wrong. So since then its not really been run at all but I'm guessing it lost a good amount of tranny fluid. I managed to get hold of a reasonable local dealer who recommended just draining and refilling with fluid and not bother flushing it. I'm more inclined to flush it anyway and replace the filter to be to be sure.
   / Help - Engine oil in the transmission! #4
That will work. The dealer is right flushing is not necessary to get the oil out but will help with making sure everything is clean.
Awesome, thanks Dave. Its a good way to learn ;-)
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A57880)
2007 FREIGHTLINER...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A57880)
2019 KENWORTH T680...
Zero Turn Mower (A55853)
Zero Turn Mower...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
