MichiganIron
Silver Member, Advertiser
- Joined
- May 12, 2008
- Messages
- 834
- Location
- Central Michigan
- Tractor
- Full line of KIOTI Tractors, BEFCO and Worksaver Implements
Sounds like a load test on the battery is in order, or a slow blow fuse. There is a 60amp slow blow fuse on the main electrical harness. It is wrapped in black tape near the stater motor. Load test the battery and continuity check the slow blow fuse.
If it is the slow blow fuse, you should check for a short it the main harness.
