HELP! Did I do something really bad to my B7300?
   / HELP! Did I do something really bad to my B7300?
Steve,
That would be great, if and when you have the time. I'd sure appreciate it!
--Chris
   / HELP! Did I do something really bad to my B7300? #32
I'd like to mention a caution for those folks who add compressed air to the tractor cases.
If compressed air is applied to the case while the oil and cases are very warm to hot, they risk an explosion. I cannot provide an analysis of why, only what I was taught through experiences of others. My uncle knew of more than one person who was injured because of using compressed air while changing the oil in the case.
...just something to keep in the back of our collective minds.
   / HELP! Did I do something really bad to my B7300? #33
In general most case seals can only tolerate pressures in the range of 10-20 psi. anything more than that and you will most likely damage them. This can then turn into a costly repair if you can't do the work yourself. If you do try to pressurize the case keep it aorund 10 psi. Then the obvious warning of high pressure anything(air/fluids) can cause serious damage to the machine or the person near it...
   / HELP! Did I do something really bad to my B7300? #34
Bit late to the show, but haven't been on in a bit...
<font color="blue"> I fired up the tractor, and kept my foot on the clutch for about 1 minute. </font>
Kubota sent me a sort of a recall notice which was a service update and a sticker that I was supposed to put on my dash, but lost /forums/images/graemlins/wink.gif. Anyway, it said that every time I start my tractor I should keep the clutch pedal depressed for at least 30 seconds.
From what I could gather from the rather vague service notice there is an issue with the hydraulic pump cavitating (not pumping) upon startup, which could lead to all kinds of stuff not working.
Anyway, I always practice counting to 45 or so and do left leg pushes on the clutch when I start my tractor. With no fluid pressure the hydraulics won't work - so I was thinking that maybe you had something like that going on.
   / HELP! Did I do something really bad to my B7300? #35
Climber.
Just some extra info so you know why/what you did when trying to bleed your hydraulic systems. First is that your tractor hydraulics is powered by a pump that is driven by your engine(located at the front of the engine). This pump shares the same resivour that the HST unit uses. They tell you to disengage the clutch so you can bleed the tractor system pump first(this powers your 3-point, loader, steering). Then when you engage the clutch it then starts driving the pump on the HST which will then bleed by itself as well(along with cycling the pedal). By doing one first then the other it just helps eliminate problems with excessive air in the fluid. Just thought you'd be interested.
   / HELP! Did I do something really bad to my B7300? #36
a small amount (0.5 gpm) of fluid from the engine driven pump is fed at a constant rate to aid in charging the transmission pump. there is also a charge pump driven from the clutch, but they want all air out of the hydrostatic transmission before things start turning.
   / HELP! Did I do something really bad to my B7300? #37
<font color="blue"> a small amount (0.5 gpm) of fluid from the engine driven pump is fed at a constant rate to aid in charging the transmission pump.</font>
This is incorrect. The tractor hydraulics delivery circuit is completely separate from the HST unit but they do share the same resivour. The engine driven pump(tractor hydraulics) is directly connected to the priority/flow divider, the flow divider has one line that feeds the 3-point control. The suction line is connected to the transmission case. The HST unit does have a charge pump located at the front of the HST unit. It is driven by the HST input shaft which is connected to the driveshaft, this part is correct. The charge pump on the HST unit is what provides the necessary fluid for internal losses within the HST unit. The tractor hydraulics pump does not provide this functionality.
It should have been stated:
<font color="purple"> a small amount (0.5 gpm) of fluid from the HST charge pump is fed at a constant rate to the pump/motor circuit within the HST unit to compensate for internal circuit losses.
</font>
I hope this clears things up.
   / HELP! Did I do something really bad to my B7300? #38
I beg to differ - The B7300 IS different in the way they divert (flow priority valve) this flow. Do you have access to the hydraulic circuit of the B7300 hydro? I can e-mail you a jpg if you want.
   / HELP! Did I do something really bad to my B7300? #39
Yes is I do have the diagrams. The first one shows the separate tractor hydraulics, the next one shows the return to tank lines.
   / HELP! Did I do something really bad to my B7300? #40
2nd
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
