Help converting skid steer to JD quick attach
   / Help converting skid steer to JD quick attach #1
andrewj
Platinum Member
South Carolina
JD 5105
I have a skid steer set of forks, and I'd like to convert them to JD QA. I saw a post on here about a year ago on how to do this and printed it out and promptly lost it. What search terms should I use to dig this up? Or do any of you recall the post? had a couple of nice pictures on it too. Thanks!
   / Help converting skid steer to JD quick attach #2
ATI makes the Tach-All, of which there are different models to convert any of the more common loader QAs to a skidsteer QA. Here is their brochure, the different models are listed on page 2: http://www.preseeder.com/PDF/TachAllQAFlyer03_05.pdf. Good luck.
   / Help converting skid steer to JD quick attach #3
I suggest selling your skid steer fork frame and buy a fork frame from Artillian (member/advertiser). It will have the JD QD and should give you a better resulting lift capacity as it is designed specifically for the JD loaders.
I don't have a fork frame. I just have my tractor with JD QA, my bucket to use as a model and the forks which are foregn to me, and a welder and some welding rods.
   / Help converting skid steer to JD quick attach #5
Then definitely visit Artillian's site. I think he offers a "build it yourself" kit if you don't want to buy the completed attachment.
   / Help converting skid steer to JD quick attach #6
I built my own, I started with a 3x3x1/4 angle and made an 18"x50" rectangular frame with 2 verticals on each end to make a 6"x18" bearing surface for the loader arms. I then used a short piece of the angle to make the top hooks, just lapped it over the top angle until it was the right hook depth. Then used a piece of flat bar to make an angled slide to make it easier to line up, and also help reinforce the angle bracket. and then 2 pieces of 1 1/4 round bar for the pins. You cant see in these pics but the 1 1/4" round bar goes through the frame and welds to both pieces of angle. I am not good at pictues or writing but it was all pretty easy once I got going. If you need specific pictures I can get them for you, actually I have made several of these. I even made an adapter plate on my skid steer to use my JD attachments.
2005 Northwood Artic Fox 335V T/A 34ft. 5th Wheel Travel Trailer (A48082)
2005 Northwood...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A48081)
2008 Ford F-250...
71092 (A49346)
71092 (A49346)
2009 Chevrolet Traverse LS SUV (A48082)
2009 Chevrolet...
UNUSED Steel Diamond Plate (A50860)
UNUSED Steel...
