Tiller Help! Clay packed into tiller tines
   / Help! Clay packed into tiller tines #11
Since you're asking for help to clear the tiller and not criticism.... have you tried a power washer?
That値l be the easiest.
No operator error involved. Just very difficult material to work up.
   / Help! Clay packed into tiller tines #12
I clogged mine doing a neighbors garden spot I told him was too wet to till, and then hit a REALLY soft spot in it. A long handle crowbar using the pointed end dug mine out without too much problem. I had mine on the tractor, lift up and every so often fired it up to help sling the stuff off.
   / Help! Clay packed into tiller tines #13
Sounds like the perfect excuse, ah, err, I mean justification, for the OP to purchase a larger trailer, water tank, gas-powered pressure washer, tool boxes for the trailer, more tools, a generator and some portable lighting, perhaps a pole barn and a well. ;)
   / Help! Clay packed into tiller tines #14
I have put my tiller away when it was a sticky mess but not even close to your mess. :D
If the mud is still dry, hook the tiller up to the tractor, put the pto in neutral, lower the 3-point hitch all the way down and go for a ride. Go fast enough to get the tiller to bounce enough to loosen the dried and caked on mess. If it is dry enough, most the clay will bust apart and fall off. If it is still a little moist, this won't work nearly as well.
Oh, and drive a straight line and raise the tiller when turning. If you make any turns with the tiller on the ground, the tines will dig in and tear up the grass.
Try it, it works for me.
   / Help! Clay packed into tiller tines #15
Kinda related: 1) The rice tillers that came over on the grey-market Yanmars have slender blades with a curve at the end, not the right-angle wide blade common on a US tiller. I assume this clogs less for tilling mud. Used in our US applications, the result is the same as a US tiller. (photo).
2)My problem is tilling tall grass where I haven't mowed. I made a tool to clean grass out of the tines - a cheap HF linoleum knife stripped and driven into the end of a piece of light conduit. This alternated with a spear might get mud out.
   / Help! Clay packed into tiller tines #16
Not on a tiller but I have cleared dry red clay with a water hose. It take s a while to get it loose.
The pressure washer idea may be better but sounds messy. I would certainly give that a try.
Thanks everybody. Got it clear today. (I had already tried the “dry tilling” and no luck). It took 3 hours to do the 2-1/2 center cavities that were still packed. I used a 0 tip on my pressure washer along with a wrecking bar hammered into the notches. From that I have about 150# of rock hard clay in my wheelbarrow from those compartments alone.
   / Help! Clay packed into tiller tines #18
YIKES!
Knock on wood I have sandy soil! :thumbsup:
   / Help! Clay packed into tiller tines #19
I bet that was a messy job. Was there much spray-back? I'm guessing that you looked like the wheelbarrow by the end of the wash.
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
