Help choose tiller
/ Help choose tiller #1
huberdoo
Central Texas
JD 3032E
I have a Kubota B2400 4x4 HST & 351FEl and want to get a tiller.
I have found 2 countyline 48" tillers and need advice on which might be best
for my 2.5 acres good loamy soil. One is new model TG 48 from Tractor Supply for $1325. The other is a model XB 48 slightly used (bought new Jan 2011) for $1250. I think the model TG 48 is about 600 lbs vs 500 for the XB.
Thanks for your advice.
/ Help choose tiller #2
How much was the xb new?,,, I got a used one for $500, but the blades were toast so I got new ones for $235?? About,now it works like new
There doesn't seem to be a lot of $ saved. In the used one, with the new one you"ll get a warranty
The owner said he paid $1325 for the XB in Jan. I would much rather buy the
new one from a money standpoint. The owner of the XB says that it is better
design for my tractor than is the TG model. I can,t see any difference by just
looking other than the 100 lbs weight .
/ Help choose tiller #4
That 100 lb will make it stay in the ground better. May not help on loose soil, but will cut sod better.
/ Help choose tiller #5
I had a deposit on. The 60" TSC TILLER until I came across the used one, I thought that for the price the TSC tiller was a deal, if you wait they do drop them $100 every once in while , the store manager has the option to discount it
/ Help choose tiller #6
I use a Woods GTR60 reverse rotation on my BX2350. Some might say that it is a little too big at 60" but I find that if I don't go at a break neck speed it works very well in my heavy clay soil. Forward rotation is easier on the tractor but the reverse rotation dose a much better job at burying weeds and such. My tiller weighs in at 496#'s and has a slip clutch instead of a shear bolt, with the amount of rocks that I have I would have to be buying shear bolts by the freight car load.
/ Help choose tiller #7
I'm buying a 48" Taylor-Pittsburg tiller new for $1200 at Barlows a week from Saturday. I wouldn't spend new money on a used machine with no warranty.
Ian
/ Help choose tiller #8
offer $800-$900 if he doesn'd bite take the new one. you have a warranty, and it's history.
Thanks to all of you for your help. I am going for the new 48" Countyline
(King Kutter) , I will post a follow up after I use it for awhile.:thumbsup:
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
6' 3Pt Bush Hog Mower (A66408)
6' 3Pt Bush Hog...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
