Help changing hydraulic fitting
/ Help changing hydraulic fitting #1
Tibbits
L3430 GST, BX1500
One of the quick release fittings on the FEL control box needs to be replaced. The FEL is not mounted and I think the way to do this is:
-engine off
-eye protection
-move FEL control lever around, all directions
-wrench off fitting slowly in case there is any pressure
I don't want a hydraulic skin injection! Could someone verify the above will be harmless?
/ Help changing hydraulic fitting #2
That's it...If the engine is off then there is no risk of fluid injection.
Thanks kennyd. I was a little nervous about this one.
/ Help changing hydraulic fitting #4
procedure is about right. engine off, crack line slowly with 2 wrenches. one to hold nut and other hold line from turning to prevent damage.
