Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab
   / Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab #1
BlakeEatmon
wilson,nc
john deere
I currently have a 2007 JD 4520 ehydro OS with FEL that I have been using for maintaining 10 acres around my home. Mainly bush hogging, loader work, grading driveway etc. I recently purchased the adjacent 100 acres next to my house and I'm looking at upgrading to a cabbed tractor. It mainly consists of woods but it has several 30 food wide paths that will have to be maintained as well as a five acre field that I plan to keep planted year round for wildlife. That will be the main uses for my tractor other than loader work, some clearing, additional food plots etc. I like the hydrostatic drive of the 4720 but I'm also thinking it may be good to go up in size to one of the 5000 series machines. I will be doing a lot more loader work and pulling a disc. Thinking that the M series might be a little bit overkill but worried that the E series machine will not be as nice as what I already have other than a cab. Please chime in guys. I would like to make a decision soon and need some input. Thanks in advance!
   / Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab #2
I have a similar situation. We own 120 acre farm, 70% woods and 30% fields. I had been using a oliver 550 and a john deere 4320 to maintain the farm and put in about 15 acres of plots. I have 30 acres that I rent out. I just ordered a john deere 5085e(check out the JD forum for options). I should have it by February. I was tired of the bugs and dust in the summer and the cold of winter. I also wanted to in the future farm all the tillable land. I just couldn't justify another 10 grand for m series tractor. I been researching for 3 months and looked at a lot of tractors. Dollar for dollar the 85e seems like a great machine for the money. It's more tractor then I need now, but I know I'll grow into it.
Thanks for sharing. After going out to my dealer today and looking again, I have narrowed it down to the 5000 series for sure. Now to make a decision between the E and the M. Can anyone tell me what the exact differences are besides the cab layout?
   / Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab #4
I can only speak of the 85 series. The m's have electronic 3 point, external 3 point hyd. cylinder(lifts 1300lbs more then the e, also upgradable to more weight) Has adjustable sway bars instead of chains for 3 point, You can upgrade to this on the 85e model. Built heavier, with new 85e model there is 500lbs between the E and M. M has more hydraulic output, I believe 2 or 3 GPM more. From what I've seen the cab in the E model and M model are the same now unless you pick the deluxe cab for the M series. M also has most functions push button(electric over hydraulic) where the E is manual levers. Looks like since the E went to tier 4 the motors almost identical. They also come with air seat, upgrade for E. Both doors open on M, upgrade for E. You can only get bias tires on E, M comes with radials. There both built in Georgia. If they wouldn't of updated the E last year I think I would have waited to save some more money for the M. I believe the E is a lot closer to the m now. Hope this helps, not sure how it stacks up with the 75's
   / Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab #5
if your going to buy 1 of the tractors go with the 5075 no q about it.
   / Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab #6
I wouldn't think you would be gaining much going from a 4520 to a 4720, other than the cab. What size disk will you be pulling? Any other equipment, planters, cultipacker, hay baling equipment? Since you like the hydrostatic you currently have I would suggest getting a hydraulic shuttle.
   / Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab #7
The 5075E is actually made in India.
   / Help,Can't decide - New JD4720 Cab or JD5075E Cab or JD 5065M Cab #9
I was only speaking of the 5085e.
I know, I was just pointing it out since it's one of the models he mentioned, and the other two are made in Georgia (which is a good thing). R,
Toro Z Master Mower (A50324)
Toro Z Master...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52128)
Michelin CARGOXBIB...
JOHN DEERE 250 SKID STEER (A51242)
JOHN DEERE 250...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
Excavator Bucket (A50514)
Excavator Bucket...
