Help! Cannot disconnect roto tiller properly.
   / Help! Cannot disconnect roto tiller properly. #1
Tippin
Didsbury, Alberta
Deutz-allis 436
Very new to the tractor world. Would appreciate a step by step instruction on how to disconnect my roto tiller:)
Thanks so much
   / Help! Cannot disconnect roto tiller properly. #2
Thanks so much
Welcome to TBN. You will have a better description if you list the type and model of your tractor and tilller. Somebody will likely have the same set up and/or befamiliar with the one you have.:thumbsup:
   / Help! Cannot disconnect roto tiller properly. #3
I found the very best way to get help is to post
up pictures...its fast and they tell a thousand tales!
The talent here is awsome, but mind readers they are not...
Try it, you might like it! :thumbsup:
   / Help! Cannot disconnect roto tiller properly. #4
Thanks so much
Choose a flat area to park it. With tiller raised, lower the jack stand leg. Lower the tiller. Unhook the top link from tiller and secure to tractor. Unhook PTO, depending on type of PTO collar you either need to fully depress a button on the collar or fully push the tractor end of the collar rearward. With the button depressed or the collar depressed pull rearward on the PTO shaft to disconnect. Unhook both lower links and you are done.
Hope this helps.
   / Help! Cannot disconnect roto tiller properly. #5
Thanks so much
First step is to turn off the PTO
Second Step. Verify that the PTO is off
Now follow the other instructions ^^^ :thumbsup:
   / Help! Cannot disconnect roto tiller properly. #6
Agree with the others that more information is needed. A photo would be great. How the PTO shaft connects to the tractor is another essential bit of info.
What, specifically, is causing the problem?
If the tiller doesn't have a built-in stand then measure the distance from the front of the tiller to the ground and cut a 4x4 post that length (probably 12" (30 cm) or so. Place the post to keep the tiller from falling forward when everything is disconnected.
You'll have to lengthen or shorten the top link to free up the top link pin. Remove the pin and secure the top link out of the way.
Then remove the PTO shaft at the tractor connection. A push pin or retracting collar are the most usual securing devices. (Later, store the PTO shaft in two pieces so it doesn't rust together and can't be extended.)
Remove the lynch pin on each side of the lower lift arms and slide the arms off of the tiller's lift pins.
Everything should be unattached now. Drive away.
This post is in English. Translating to Australian is your responsibility.:laughing:
1999-2010 Ford Pickup Truck Bed (A52377)
1999-2010 Ford...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
18-1 gallon jugs pure Anti-freeze (A53117)
18-1 gallon jugs...
Bretford Rolling Table (A51695)
Bretford Rolling...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
