HELP - BX23 Bagger Repairs/Maintenance
   / HELP - BX23 Bagger Repairs/Maintenance #1
AMR
Woodbury, CT
B3030
I let the grass go a week and it went crazy with all the rain we have had. I started to mow last night and about 100' down my first pass the bagger turbine stopped while the PTO shaft continued to spin. I could hear a pretty good squeeling noise so I shut everything down and headed for the garage.
I took the long bent plate off to have a look and found that the shoulder bolt holding the shaft onto the PTO gearbox shaft was sheared off. Not an easy bolt to find at 5:30 PM hear in CT. I found a Case dealer that would stay open late and try to match it, no luck matching it but he did order me up a bunch, to get by I was able to put a hardened hex bolt in, it appeared to work just fine.
HOWEVER, I did notice that there was about a teaspoon of gearbox oil underneath the PTO gearbox. No obvious leaks, maybe it was sneaking around the shaft seal. I could see plainly how to drain the gearbox but no sign of a filler or any way to check the oil. Can anyone help me with that? How do you chekc/change the gearbox oil on this thing? Thanks for any help.
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
Toyota Prius NR (A50324)
Toyota Prius NR...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
Chipper (A50774)
Chipper (A50774)
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
