Help buying a MF135
   / Help buying a MF135 #1
ArcherXC
Bronze Member
Swansea, SC
1965 Massey Ferguson 135
I've been looking for a MF135. I found one that need advice on. It's been in a shed for over 5 years and can't be run now. It needs a battery, gas tank clean out, and some TLC. It doesn't look to bad. The seller is asking $2800 for it as is. Should I even consider it since I can't run it to check it? How would I check it without running it?
   / Help buying a MF135 #2
Welcome! Its always better to have one running I feel. Awful hard to judge without seeing it. If you can take someone with you who knows how to evaluate them is what I would do. Seems high to me for not running, to many unknowns. Anything go with it? Its gambling for sure but you could be getting a deal. Good luck.
v/r
Mike
   / Help buying a MF135 #3
Offer him 2 grand.
   / Help buying a MF135 #4
I think that $2800 is high for it not running. I know a guy that bought a 135 diesel a couple of years ago for $3100, that may have even been a little high for it. I am assuming that it is a gas motor since you said gas tank? Like you said it will need a battery and the gas tank cleaned plus a tune up, it should have all of the fluids changed, probably hoses and a belt but you won't know if then engine is any good til you can get it running, or the hydraulic system. You could be buying a good tractor or a money pit. I believe I would look for something else unless he dropped the price drastically. There is usually a reason why someone will sell something not running, it usually needs major work.
   / Help buying a MF135 #5
I'd pass on this one--too risky. Find one that's running so you can do a thorough checkout before buying.
   / Help buying a MF135 #6
I agree... I don't buy non runners unless they are 500$ or less.
if the seller thinks they have a 2800$ machine.. then they can go buy swap the battery out of their truck for a test and rig up a small fuel tank and prove it.. or just buy the 100$ battery and cleanthe tank for a few bucks...
soundguy
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A55218)
2019 Energreen EVO...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
