Help buying a MF135
/ Help buying a MF135 #1
ArcherXC
Swansea, SC
1965 Massey Ferguson 135
I've been looking for a MF135. I found one that need advice on. It's been in a shed for over 5 years and can't be run now. It needs a battery, gas tank clean out, and some TLC. It doesn't look to bad. The seller is asking $2800 for it as is. Should I even consider it since I can't run it to check it? How would I check it without running it?
/ Help buying a MF135 #2
Welcome! Its always better to have one running I feel. Awful hard to judge without seeing it. If you can take someone with you who knows how to evaluate them is what I would do. Seems high to me for not running, to many unknowns. Anything go with it? Its gambling for sure but you could be getting a deal. Good luck.
v/r
Mike
/ Help buying a MF135 #3
Offer him 2 grand.
/ Help buying a MF135 #4
I think that $2800 is high for it not running. I know a guy that bought a 135 diesel a couple of years ago for $3100, that may have even been a little high for it. I am assuming that it is a gas motor since you said gas tank? Like you said it will need a battery and the gas tank cleaned plus a tune up, it should have all of the fluids changed, probably hoses and a belt but you won't know if then engine is any good til you can get it running, or the hydraulic system. You could be buying a good tractor or a money pit. I believe I would look for something else unless he dropped the price drastically. There is usually a reason why someone will sell something not running, it usually needs major work.
/ Help buying a MF135 #5
I'd pass on this one--too risky. Find one that's running so you can do a thorough checkout before buying.
/ Help buying a MF135 #6
I agree... I don't buy non runners unless they are 500$ or less.
if the seller thinks they have a 2800$ machine.. then they can go buy swap the battery out of their truck for a test and rig up a small fuel tank and prove it.. or just buy the 100$ battery and cleanthe tank for a few bucks...
soundguy
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
