Help! Branson Tractor only IDLES - no Power
   / Help! Branson Tractor only IDLES - no Power #31
C:\Users\jflyn\OneDrive\Desktop\Teijin RFQ automotive\IMG_1613.MOV
You have to upload the video to a platform like Youtube, Vimeo, or similar. The forum doesn't allow for the video to be posted directly.
   / Help! Branson Tractor only IDLES - no Power #32
OK. Yeah, without cookin' it for a couple of hours at 500C blowing and washing it out doesn't do much. I've used a modified ceramic kiln myself before. One way to make for sure that is it is to pull the plug in the exhaust manifold are try running it for just a few seconds without the DPF installed.
Looking for advice and help on a Branson Tractor Model 4720H..
Long Story short... My fathernlaw borrowed a neighbors tractor right before he was diagnosis with Stage 4 Brain Cancer and apparently it messed up on him while he was using it... He has since passed and now i have inherited the problem to fix.
Before he passed he had ordered a new fuel pump and said that is all that was needed as it wasnt getting fuel
.. I installed it and noticed that the fuel filter assembly needed replaced as well which i also installed.
The problem still is the same... New fuel line, new diesel fuel, blown air back into tank to check if any clogs, new air filter have all been installed. It seems like the tractor is getting fuel but did notice.....
the dpf lamp would flash quick 10 times when keyswitch is turned on.... so i took the DPF filter out, cleaned it, and reinstalled... Still no power, just idles.
Any advice is greatly appreciated!.
Limp home mode?
   / Help! Branson Tractor only IDLES - no Power #33
Well I had an older Chevy with a hydromechanical fuel injection system do the very same thing. It would start and idle fine but no acceleration. It turned out to be the advance mechanism in the fuel injection pump had broken. A fuel injection pump rebuild fixed it. I have never worked on a Branson but this sounds to be the very same.
   / Help! Branson Tractor only IDLES - no Power #34
Hi to me it look like the injection pump is seized on idle put some lubrication product in the fuel and when tractor is idling play with the throtle several times .
   / Help! Branson Tractor only IDLES - no Power #35
My 2005 Branson 4220 is doing the exact same thing, getting plenty of fuel to injector pump, move throttle lever by hand still only idles, this started up after sitting for awhile so I may have to take injector pump off as it may be stuck
Reason I posted this I wonder what the original poster found out last year I did not notice anything saying he fixed problem
   / Help! Branson Tractor only IDLES - no Power #36
When you move the throttle lever back & forth, can you see the cable move at the engine, maybe its loose.
Have you changed your fuel filter lately?
If you haven't used it in a while, check your air cleaner for a mouse nest.....
I use to own a 4220 tlb, great machine!
   / Help! Branson Tractor only IDLES - no Power #37
The throttle cable should be attached to a lever on the injection pump, and the lever should move when the throttle lever is moved.
   / Help! Branson Tractor only IDLES - no Power #38
Speed Test
Does it sound like it's trying to increase rpms and struggling to do so? Or is it totally ignoring the throttle lever and just sitting there idling? In the latter case I'd watch the actuator arm on the FI pump while opening the throttle to see if it's moving.
   / Help! Branson Tractor only IDLES - no Power #39
It's a Branson. It starts? Good enough. :rolleyes:
   / Help! Branson Tractor only IDLES - no Power #40
OK. DPF definitely isn't the issue then. As long as you're getting plenty of fuel to the injection pump and plenty of air to the engine. Outside of extremely low compression, about the only thing it leaves is extremely tight valve lash or injection pump is wore out. I'm assuming you've already made sure the accelerator cable is operating the pump correctly.
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
TANK MANIFOLD (A55745)
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
