Help bobcat s130 eletrical problem Wont move or lift
   / Help bobcat s130 eletrical problem Wont move or lift #1
bobcats130
dracut ma
2003 bobcat s130
Hi
I recently bought a 2003 bobcat s130 that would only drive no lift wouldn't unlock upon investigation needed a safety bar switch the hack before me cut off the connector trying to override it but you cant I put a switch in it and i think I wired everything right the only thing that came alive was the hand controls for the loader will work but foot controls wont unlock was working good but machine would work with the safety bar up so still wasn't wired right rewired it so safety bar would kill everything worked for 3 or 4 times turning the machine on and off now everything is dead again motor will start and idle wont give codes no headlights control box will light up give hrs show gas and temp nothing else need help
harness break ?
shorted out controller box ?
   / Help bobcat s130 eletrical problem Wont move or lift #2
Maybe try posting on the Bobcat construction equipment forum in another part of Tractor By Net. If you're lucky, Dennis (SSDoxie) will come up with some suggestions for you. He certainly seems to be on top of Bobcat issues.
ok thank you i will try that right now
(APPROX 26) 2" X 6" X 78" TUBING (A51247)
(APPROX 26) 2" X...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
More info coming soon! (A50322)
More info coming...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
