Help bobcat s130 eletrical problem Wont move or lift
   / Help bobcat s130 eletrical problem Wont move or lift #1
bobcats130
dracut ma
2003 bobcat s130
Hi
I recently bought a 2003 bobcat s130 that would only drive no lift wouldn't unlock upon investigation needed a safety bar switch the hack before me cut off the connector trying to override it but you cant I put a switch in it and i think I wired everything right the only thing that came alive was the hand controls for the loader will work but foot controls wont unlock was working good but machine would work with the safety bar up so still wasn't wired right rewired it so safety bar would kill everything worked for 3 or 4 times turning the machine on and off now everything is dead again motor will start and idle wont give codes no headlights control box will light up give hrs show gas and temp nothing else need help
harness break ?
shorted out controller box ?
   / Help bobcat s130 eletrical problem Wont move or lift #2
Maybe try posting on the Bobcat construction equipment forum in another part of Tractor By Net. If you're lucky, Dennis (SSDoxie) will come up with some suggestions for you. He certainly seems to be on top of Bobcat issues.
ok thank you i will try that right now
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2022 UTILITY FS2CHA 48FT FLATBED TRAILER (A53426)
2022 UTILITY...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2020 INTERNATIONAL LT625 DAY CAB (A53426)
2020 INTERNATIONAL...
