Help - BH bucket won't go on NH757c
   / Help - BH bucket won't go on NH757c #1
lhfarm
Central Indiana
NH TC40DA
Help - BH bucket won\'t go on NH757c
I've just spent 2 hours (in 90+ heat) trying to put a new 12" bucket on my BH. I can put either pin - front or rear -OK, but the second one hits a lip on the opposite side. I've pounded on everything I can think of and I've put the bucket in every position. I think the bucket is mis-aligned. I have tried twisting it, but I am not strong enough to get it to move.
I have thought about grinding the pin down, at least taking the square shoulders off. Just from feeling with my finger, I would guess the lip is at least 1/16". I don't know how much of a taper I would need to get by it.
Anyone have a suggestion? I don't want to return it if I don't have to. I'm trying to get some drain pipe in.
Thanks,
   / Help - BH bucket won't go on NH757c #2
Re: Help - BH bucket won\'t go on NH757c
If I thought by grinding the edges down a bit would allow it to slide in, I sure would. Also grease it up and tap it in with a hammer. I had to cut a pin down, drill a new hole & round the edges to get it to fit on the top link under my backhoe.
I tried taking the shoulders off and that did it. It still took a small sledge and some good smacks. Sure hope I can get it out. Boy, I had expected to spend 15 minutes changing a bucket and I spent over 2 hours /forums/images/graemlins/mad.gif!
Thanks for the advice. Now if I can just get it to dry out enough to do the trenching.
Thanks,
Econoline RA-48X24 Sand Blaster (A53117)
Econoline RA-48X24...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
Towable Diesel Tank (A53421)
Towable Diesel...
