HELP! B2910 won't start!
   / HELP! B2910 won't start! #1
dlabrie
Campton, NH
Kubota B2910
HELP! B2910 won\'t start!
I am in the middle of a big project and my tractor won't start! It has 100 hours on it and I have had it for 13 months. I parked it and when I went to start it I got nothing at all. No crank, click or anything. I made sure the PTOs were not engaged, the clutch was pressesd down. I checked the fuses on the RF firewall, they were OK. Oil and Hydro fluids OK. Lights shine brightly. What am I missing?
Thanks David
   / HELP! B2910 won't start! #2
Re: HELP! B2910 won\'t start!
<font color=blue>PTOs were not engaged, the clutch was pressesd down</font color=blue>
And the range selector lever was in one of the "neutral" positions? I'd probably start by moving the range selector lever forward and backward while holding the key in the start position to see if a safety switch was not adjusted just right. If that didn't help, I'd try the same thing with the PTO engagement levers, and if that didn't work, I'd be looking under there to see if a wire was loose from one of the safety switches (or somewhere else).
Bird,
I have never had to have the range selector lever in a neutral position. It has always started in any position. I went out and tried what you suggested but it didn't work. I can't seem to shift the rear PTO lever out of the off position . It is getting dark now and will have to look for the safety switches in the AM.
Thanks,
David
   / HELP! B2910 won't start! #4
I think there's another in-line fuse by the starter. Not positive exactly where or what its for, but you could check that.
   / HELP! B2910 won't start! #5
Hayden, that fuse is for the main power. Without that you will not have any power to anything. I'm pretty sure they moved the switch from the range shifter to the HST pedal. Try rocking the pedal while holding the key to start, make sure the range shifter is in neutral to avoid going for an un expected ride. The problem they were having was if you stopped in gear and the machine was loaded up, say on a slight incline or jammed into a pile. You couldn't get the range shifter back into neutral due to gear wind up. So they moved it to the pedal.
   / HELP! B2910 won't start! #6
Thanks, Kubmech; I didn't know they'd moved that one.
"Try rocking the pedal while holding the key to start ..."
Art (Kubmech),
THANKS!!! It worked!!! I was getting worried because the service dept at the local dealership is less than stellar. They are also very slow at getting to your equipment. Where is the safety switch for the speed control? If it is going bad I'd like to replace it.
Thanks to all the TBNers who so generously give of their time to help each other out.
David
   / HELP! B2910 won't start! #8
I can't remember for sure, If it's not in the area of the pedal, it may be on the left side behind the rear fender. Linkage runs to the left for the "cruise control".
   / HELP! B2910 won't start! #9
I knew there was no interlock on the range shifter (my old B2400 had one and I disabled it), but I never knew there was one on the HST peddle. Learn something new every day.
   / HELP! B2910 won't start! #10
I have a 2710...and have had problems starting it at times.
I finally figured out that the safety switches were not adjusted
properly. All three of them caused me problems, and they are not that easy to get to and get them adjusted. But no problems since getting them right. And they never seem to be a problem when parked next to the shop.
PR
71062 (A49346)
71062 (A49346)
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2022 Ford F-150...
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
