Posthole Digger Help! are replacement augers for 3-point post diggers all universal?
   / Help! are replacement augers for 3-point post diggers all universal? #11
The Pengo and Danuser brands are top of the line. Very good in every regard. They also cost a lot more and for most of us using a 3 point hitch to drill post holes, not worth the extra money. If you go that route, you really should look into a hydraulic motor to run them, and a mount for your front loader to operate it. Even better is to mount one on an excavator!!!! But for most of us, I don't think you can find a better value then the Country Line brand at Tractor Supply.
I won't dispute that at all. My 12" Speeco did my fence & 2 side jobs. It still had a good amount of life left when I sold it. Well the teeth were shot but I got a spare set. Welding a little reinforcement on the collar would have fixed the tearing problem. I just officially spun up a side gig doing tractor work, so I'm guessing I'll easily be putting in a few hundred holes a year now. Puts me past the homeowner class gear a touch.
The Speeco teeth were $12-15 each (inner & an outer). My Pengo teeth were $5 each (needed 4). As near as I can tell both only last a job or 2 (50-200 holes). Likely going for the $10 hard faced teeth next, probably not the $20 carbide ones.
   / Help! are replacement augers for 3-point post diggers all universal? #12
I have a 9" Leinbach auger that I bent accidently backing up. Used a 20 ton press to straighten it. Easy to do.
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2003 McCormick XTX 185 XtraSpeed Tractor (A57024)
2003 McCormick XTX...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
