Help - 6x4 diesel gator won't start
   / Help - 6x4 diesel gator won't start
Yes it was running before this happened. I used it over last weekend, paked it then came back 2 days later and it would not start. The glow plugs do not function (did last weekend) so I replaced the glow plug relay and the ignition switch.
Yep, air is good - cleaned filter.
   / Help - 6x4 diesel gator won't start #15
there is a switch i really don't know what it's for but it could be causeing your problem. this wireing diagram might help.
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 AT75769 RELAY 2
2 AM100819 MODULE 1 GLOW PLUG
3 37M7091 SCREW 3 M6 X 25
4 M75140 CLIP 1
5 AM127194 WIRING HARNESS 1 (SUB VGA10762) (SUB FOR AM119963)
6 H77698 TIE BAND 1 (SUB FOR M66044)
7 M46449 BOOT 1
8 14M7397 LOCK NUT 1 M6
9 19M7866 SCREW 1 M8 X 20
10 M45242 CLIP 1
11 12M7065 LOCK WASHER 1 8 MM
12 14M7273 NUT 1 M8
13 14M7298 FLANGE NUT 1 M8
14 14M7396 LOCK NUT 1 M8
15 M95345 BOOT 2
16 AM128925 SWITCH 2 STOP, (SUB FOR AM115055)
17 19M7373 CAP SCREW 2 M5 X 20
18 14M7265 LOCK NUT 2 M5
19 T24167 ELECTRICAL CONNECTOR ASSY 2
20 T28585 ELECTRICAL CONNECTOR ASSY 3
21 T28583 ELEC. CONNECTOR HOUSING 1
22 AM131841 KEY 1 (SUB FOR AM101600)
23 M110159 NUT 1
24 AM107076 KIT 1 BOOT REPAIR
25 TCA15075 ROTARY SWITCH 1 IGNITION, (SUB FOR AM101561)
26 AR62407 BULB 5
27 AM125633 JUMPER 1 AUXILIARY ALTERNATOR DISCHARGE LIGHT
Get a sneak peek of the all-new AOL.com.
   / Help - 6x4 diesel gator won't start #16
The symptoms sound like a fuel problem--because the engine is cranking and there is no electrical ignition system to cause the problem.
I believe that all diesel engines have a fuel cut off that is relay operated--because that is how the engine is shut off--by closing the valve and starving the engine of fuel. If this relay fails to open no fuel will reach the engine and it will not start or run.
The literature that came with my Gator Diesel does not show the location of this relay but I think it may be located on the engine below the injector pump. It is difficult to see or work in this area without removing the bed.
   / Help - 6x4 diesel gator won't start #17
By the sounds of it he's getting fuel though. He got fuel right before the injectors I think he said. But that's why I kept asking about it, really doesn't seem like it could be anything else since there's no spark plugs.
   / Help - 6x4 diesel gator won't start #18
Doesn't something have to ignite it initially?
   / Help - 6x4 diesel gator won't start #19
Compression alone is all a diesel uses.
   / Help - 6x4 diesel gator won't start #20
then do a compression check to see if something might have blown? you might have got the answer darkday. the fuel is making it to the cylinders from what i read correct? it could be a blown head gasket or something .
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
Rooster Artwork (A55758)
Rooster Artwork...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2023 TRANSCRAFT 53FT FLATBED TRAILER (A57880)
2023 TRANSCRAFT...
2016 Chevrolet Traverse LT SUV (A55853)
2016 Chevrolet...
2003 Big Tex 10PI...
