Mowing Help!! 3PH/Underbelly mower hydro problems!
   / Help!! 3PH/Underbelly mower hydro problems! #1
MidgetMaestro
Ohio
Kubota BX2200, Farmall Cub
I recently sent my bx back (to the dealer for repair) after the implements I had mounted on the tractor kept drifting down once I stop pulling on the hydraulics lever. They sent it back saying they couldn't find any leaks, and they have no idea what's causing it to drop ... GREAT! just what i needed :eek:
Have any ideas??
I really need this fixed, cuz trying to grade with a blade that keeps drifting down is not fun :(
Thanks!
   / Help!! 3PH/Underbelly mower hydro problems! #2
The problem could be the stop adjustments on the hydraulic control lever rod. You will find the rod behind the right rear tire. It has two stops with two springs. You can reference kubotabooks.com bx2200d pages 155/156 . I had a similiar problem with the lever hitting the lift stop and dropping the implement.
thanks so much! I'll check it out!
2004 GREAT DANE 53FT DRY VAN TRAILER (A52141)
2004 GREAT DANE...
Toro Zero Turn (A50324)
Toro Zero Turn...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
2014 International 4400 DuraStar Box Truck (A47384)
2014 International...
