HELP !! 3PH CarryAll Question
   / HELP !! 3PH CarryAll Question
EDT ,
Thanks for the info , however I purchased my JD4110 from Rosencrants in Londonderry. My salesman did not know were to get one. MB Tractor in plaistow also did not have a clue. Maybe I'll try Rosencrants main office.
Mark
cchoate ,
I've called TSC and they have stated that they do not have any shipping company that will ship items of weight to New Hampshire.
I will not be lifting pallets , I am looking for an inexpensive way of transporting the supply of hay I get for the winter for the horses back to the barn. Currrently the loader will only hold 3 or 4 bails depending on size. The clamp on forks would be the best , however not at $500 for the pair.
The carryall forks could handle maybe 10 bails in combination with the few I can get into the loader. Total bails being delivered is @60 , so I will have to make a few trips , however a lot less trips than if I just use the bucket ....
Mark
   / HELP !! 3PH CarryAll Question #13
You might look for a cheap-o worn out trailer to pull behind your tractor. I use my 'retired' 4x8 to pull hay around the pasture.
If you can weld, a low capacity 3pt carry all should just require some pins, scrap angle-iron, and some sparks.
Soundguy
   / HELP !! 3PH CarryAll Question #14
Try "Knoxland Tractor" up in Dunbarton. He might have one laying around. bcs
Hello Again ,
Thanks everyone for all the info , I finally found a cat 1 3PH Carryall. The dealer info is below. Only about a 45 minute drive from my house. It is a Worksaver model - C95 Platform Carrier. It has the holes already drilled for PT decking or plywood or material of choice. 1000LB load capacity.
http://www.worksaver.com/
NorthernEastern Forklift / Cub Cadet
2080 Dover Road
Epsom , NH 03234
603.736.7800 - Ask for Jim
Marko
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2025 TMA Attenuator Truck (A52377)
2025 TMA...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
Toro Workman HDX-D Utility Cart (A55851)
Toro Workman HDX-D...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
