HELP..2816 HST Won't Start
   / HELP..2816 HST Won't Start #1
BugmanZ
Bucks County, Pa
20082816 HST
Discovered the positive battery post connector had corroded almost completely away. I disconnected the cable put on a new connector, new battery, and it won't start. Lights all work...any ideas are appreciated.:mur:
   / HELP..2816 HST Won't Start #2
How is your negative ground connection? Check your PTO levers. Are they fully disengaged?
Negative connection is tight, Ill recheck PTO's.
   / HELP..2816 HST Won't Start #4
Are you sure you got all of the + wires in the new connector ? Since the old one rotted away there may have been a smaller feed wire in the connector also that may have fallen away that can't be seen easily.
Yea, I stripped back the rubber covering @ 1/2 inch and tightened the connector. Am I missing a fuse somewhere that could've been blown? Like I mentioned, lights all work, etc. When turning the key, oil light, glow plug light and battery lite all come on, but when turning the key all the way to right, nothing.:confused2:
   / HELP..2816 HST Won't Start #6
Do the lights stay bright or go all the way dim when you turn the key all the way to the right? If they go real dim, you still have a bad connection. If they stay bright, I'd suggest a safety switch is the issue. Remember to remove the entire negative cable, clean the battery post, the inner cable and the other end where it bolts to the frame.
ok, I stopped by my Mahindra dealer tonite, but they were closing. Had a quick discussion, sounds like there's a small type of connector that should come off the positive and connect to the main connector. gonna stop back tomorrow when weve got more time.
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
JMR Tree Boom Skid Steer Attachment (A50322)
JMR Tree Boom Skid...
(4) 12-16.5 NHS TIRES & RIMS (A51243)
(4) 12-16.5 NHS...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
