Help 2500 Series Steering problem?
   / Help 2500 Series Steering problem? #11
Thank you gamble. Looks like mine is on the list so I'll be calling the dealer today... /forums/images/graemlins/frown.gif
When did the Service advisory CC-515 come out?? Is it dated?
Is there a way to get a copy? You information is great! Thanks.
   / Help 2500 Series Steering problem? #13
I wondered the same thing. I called my dealer this morning and he had no clue. He was going to check and get back to me.
   / Help 2500 Series Steering problem? #14
I'm glad you guys brought this to light. I just checked out the steering gear on my 2544 today (2005 model year). There's two zerks on the steering gear! The manual doesnt go into details about that little fact at all. The sector shaft zerk is on the right side, fairly easy to see and get at, and the pinion shaft zerk is lower on the left & hidden pretty well. You go thru an access hole in the steering support to grease it. For ether side, you have to remove the side panels. The worst part was, the pinion zerk had never been touched, unless it was given a shot of grease at the factory! Is the steering gear cast iron for the 2006's? The housing is cast aluminum on my 2005. The wear parts look to be bronze, gears are steel.
G/luck
Joel
   / Help 2500 Series Steering problem? #15
The service advisory is only a few weeks old but all the dealers should have access to it and all its information via the dealer web portal. Good luck getting yalls fixed!
   / Help 2500 Series Steering problem? #16
Gamble, are there any other advisories for 2006 2500's?
2019 Ford Explorer AWD SUV (A55853)
2019 Ford Explorer...
2015 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2015 INTERNATIONAL...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
2025 Yongkang Liqian 2 Passenger Electric Car (A55853)
2025 Yongkang...
