Help! 2015 hydraulic leak
/ Help! 2015 hydraulic leak #1
SamatGA
I have a 2015 that has developed a serious leak at what appears to be the fitting for the oil tube coming from the Hydraulic block running over the transmission and going into the rear lift. There is what appears to be a brass coupler nut at this point ( at the rear Lift) going into the top of a triangular shaped block that has three bolts holding it on. This is located at the left side of the tractor up under the seat bracket. It sprays oil onto the left rear wheel when the lift is activated but only drips otherwise. Has anyone had this problem? Is it fixable at home? Any help would be appreciated.
Thanks,
Sam
/ Help! 2015 hydraulic leak #2
please send me an email with your contact information and I'll forward to our tech service department. Please include your name, telephone information, serial number, date purcahsed, and dealer where purcahsed/serviced. You can send the email to marketing@mahindrausa.com.
/ Help! 2015 hydraulic leak #3
Gotta love that Mahindra customer service! It's really great to have you here, musa_marketing.
I hope you get it fixed quickly and as painless ($) as possible, SamatGA. Contact musa_marketing ASAP. He'll get you the help you need.
Later,
BR
/ Help! 2015 hydraulic leak #4
Its an easy fix, Follow the return line to where the leak is and tighten with a small wrench, we did one the other day, exactly what you described.When you are done check your hyd. fluid level.any problems feel free to call us Ernies imports
I got it fixed. Thanks to the help of my best friend. I told him about it and he helped me track down where the leak was coming from. The fitting was verrry loose, tightened it down and no more leak. That's the kind of repair I like. No $$$. Thanks for all your help.
Sam
/ Help! 2015 hydraulic leak #6
The 15 series use a hollow bolt with a copper gasket/washer on each side of the steel hydraulic fittings. I call these banjo fittings, but I am not sure if that is the correct technical term. You see this on the back side of the hydraulic block where the loader gets it's power, also under the seat where the line goes on to power the three-point. Some have 2 or 3 of this sort of fitting. It is a great set up, but we do occasionally see one that needs to be snugged up. It's about a 15/16", I use an offset box-end wrench. As part of the routine maintenance, it's a good idea to check these every so often. I will say that once they are tightened, I haven't seen one start leaking again. Just remember, it is a hollow bolt, so don't get carried away with the wrench.
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2021 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2021 Ford F-150...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
2019 Ford Transit 350 Police Transport Van (A61573)
2019 Ford Transit...
2022 EZ-GO ELITE...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
