Help 1301D
   / Help 1301D #1
bobjr1
Rhode Island
Yanmar 1301D
I recieved my manual today from Hoyes and it mentions a valve for slowing the drop when lowering implements. I tried to find it on my 1301D and could not. The manual is for a 1410 and my question is: Does the 1301D have this valve? Also, it says to check the dipstick on the front axle I cannot find a dipstick only a yellow fill cap. Also, where is the screen located for the hydraulics? Does anyone have a 1301D that can help it would be appreciated. Thanks for your patience.
   / Help 1301D #2
Hey Bill,
The fall rate valve should be under the left side of your seat (-as you sit) on the case housing. Small valve with a roll pin handle.
The filter screen is at the end of your large hydraulic return line..inside the case-under the tractor. Usually three bolts on the welded flange (on the large tube line) and it will come out as an assembly.
I have seen many models with, and without, the FWD dipstick attached.
Hope this helps.
Mark
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2013 INTERNATIONAL REEFER TRUCK (A53426)
2013 INTERNATIONAL...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2017 Chevrolet Express 2500 LT Passenger Van (A51692)
2017 Chevrolet...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
