Hellow from a new owner of MT2501 tractor.
   / Hellow from a new owner of MT2501 tractor. #1
MT2501owner
New Member
Houston, Texas
MT2501FD
Recently picked up an MT2501D. It needs some work. I've rebuilt lots of gas engines in my time, but this is my first project with an old diesel tractor.
Found a parts manual for the tractor and FEL, still looking for owner/service manual.
First issue may be easy, or a bit or work. Water escapes under the radiator cap even when the tractor is cold. I'm thinking it may just be a worn out cap, but since it leaks cold water, I suspect a head gasket. I know its a 13LB cap, but not sure how to track down a replacement yet.
Also the kluge of fuel lines leak. Currently it has rubber fuel lines. I thought diesel required a harder line ?
Finally, all the cylinders on the FEL leak a bit, some more than others. It's an MT2501 factory loader, hoping I can get rebuild kits for them.
I expect to spend a good bit of time on the net looking for parts, advice and guidance on this adventure.
Hopefully after this I can be a source for others.
RE
   / Hellow from a new owner of MT2501 tractor. #2
Welcome to the world of old tractors..it will be great! (Not sarcasm).
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
RoGator RG1100C (A55302)
RoGator RG1100C...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
