Hello
/ Hello #1
Rjlombardi
Kubota BX2230
My Name is Ray Lombardi
I moved to Evansville IN last year from Simi Valley CA
I was given a Kubota BX2230 several years ago
The 2001 tractor only had 200 hours on it, it did not have a mower deck.
I bought a 60鋳 mower deck for the tractor (Ouch) $3000 later
I used the tractor all last year mostly to mow a 3 acre yard.
The tractor now has over 300 hours on it.
Two days ago I notice a huge puddle of hydraulic oil under my Kubota.
The mower deck is covered, I fired up the tractor and is seems to be leaking above the drive shaft that operates the mower.
I can not see where the leak is coming from as I cannot get under the tractor.
BTW, I did have the tractor serviced last year when I purchased the mower deck
I will also post this in the forum
Cheers
Ray
/ Hello #2
Ray, Welcome to TBN and hope your leak is a simple fix.
/ Hello #3
Hi, Ray, and welcome to TBN. Don't run the tractor if low on fluid and good luck with the leak. I'm guessing the most likely culprit will be the front PTO seal but I've not seen the tractor.
/ Hello #4
:welcome: to TBN...enjoy.
/ Hello #5
:welcome:
Welcome to the forum!
I'm going to move your other thread over to our Kubota section. You should find plenty more advice over there.
/ Hello #7
Welcome to TBN! You will be able to get help here for sure!
KJ K2825 28'x25' Metal Workshop (A60463)
KJ K2825 28'x25'...
Caterpillar 906M (A53317)
Caterpillar 906M...
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
(INOP) MASSEY FERGUSON 451 TRACTOR (A59823)
(INOP) MASSEY...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
