Hello...
/ Hello... #11
.I would love to consider a John Deere...both neighbors have them and we have talked about the fact that we all have different needs...by purchasing the same model as my neighbor, I would be able to purchase different attachments that would allow us to trade needed implements back and forth as needed.
Purchasing the same model as your neighbor to trade implements is not necessary. What you will need is the same category of 3 point hitch. There are cat 0, 1, 2 and on up. The PTO all turns the same direction and same speed of 540 rpm (when tractor engine is set at PTO speed). There are some larger tractors that have 2 speed PTOs with the second being up around 1000 rpm. You will have to verify that the PTO shaft length is correct for the tractor, but I've not found that to be an issue.
/ Hello... #12
That's true for the back end... and JD offers a 3PH (3 point hitch) "iMatch" quick hitch for ease of hooking up implements. There are other brands of 3PH quick-hitches available too. Many threads on TBN about those.
Which also brings up the attachment configurations of the Front End Loader (FEL). If you plan on coordinating with your neighbours you'll need to note the FEL implement attaching system. Again, JD has their JDQA. There's the GlobalQA system, the Skid Steer Quick Attach (SSQA) system and the direct system.
2021 Honda Pioneer 700 4x4 Gas Utility Cart (A59228)
2021 Honda Pioneer...
iDrive TDS-2010H...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
RING 2 STARTS HERE @ 9:15 AM (A62130)
RING 2 STARTS HERE...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2007 International Derrick Digger Truck (A60352)
2007 International...
