Hello ,
   / Hello , #1
Tractor lady
Maysville Oklahoma
Massey Ferguson 383
Hello everyone I am new to the group
Like help with my Massey Ferguson 383
Will crank but will not run
   / Hello , #2
Welcome. Need some more info to be much help. When did it last run? Did it die or did it sit around and now will not start. Basicly needs fuel, good battery and compression. If it has been sitting and the battery is weak it may not start. Does it have glow plugs, do they work? Does it have air in the fuel (need bled)? Give us a little more info and what you have tried and we will try to help.
   / Hello , #3
Welcome to TBN.
Enjoy and do share w/us.
As Oldtractorfixer ask................
   / Hello ,
Yes I will give you more info,
The tractor was running fine turned it off then when went next time to use it which was like a couple of days later, it would just crank over and not start , but will start and run a little with starting fluid , i have changed the fuel filter had little water in the bottom of the bowl got that out so I bled the lines , still won't run , when you open up the drain plugs it ran when the top was open then when I tighten it it died
   / Hello , #9
I still tend to think at least part of the problem is you still have air in the system. The injector pump and injectors are probably good as you said it ran with the bleed screw loose. I don't know why that would work but may have something to do with the air. Try bleeding again all the way to the injectors. Not sure why it wouldn't start after a couple days but may have lost its prime for some reason.
2005 Woodchuck Chipper (NOT RUNNING) (A50775)
2005 Woodchuck...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2022 Chevrolet Tahoe FL SUV (A55758)
2022 Chevrolet...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
EXCAVATOR HYD HAMMER (A51406)
EXCAVATOR HYD...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
