Hello to Tractorbynet members
   / Hello to Tractorbynet members #1
jsppgp
Chesapeake, Va
1988 JD 655 w/50 mmm, 2008 2305 w/62 mmm & 200cx FEL, 2013 2032r w/62d mmm and mounting frame to accept the 200cx FEL
Hello all,
I've read so many good and interesting threads here and wanted to become part of this wonderful fellowship. The wife and I live in southeastern Virginia. Friday afternoon (10/25/13), I took delivery of a 2013, John Deere 2032r, with a 62" on ramp mmm and mounting frame for a 200cx FEL. We had our grand kids all weekend so I haven't had time to play with it yet. I also own a 2008 JD 2305 with a 62C mmm with a 200cx FEL( this will be used by both the 2305 and the new 2032r). I also own a 1988 JD 655 with a 50" mmm, and a Furgerson 48" tiller and a JD 134 4ft blade.
   / Hello to Tractorbynet members #2
Welcome to TBN.
I'm a new member and I don't know if this is the correct place but my JD2305 has a leaking hydraulic quick disconnect. As long as the FEL is attached it doesn't leak but if I disconnect the FEL and cut grass, one of the QD will leak. Do I need to change it or does anyone have suggestions
   / Hello to Tractorbynet members #6
:welcome: from SW Ohio
lot of tractors with mowers
What cha mowing with so many mowers???
   / Hello to Tractorbynet members #7
It sounds like the QD itself is leaking from around the ball not the threads. I think the only way to fix it is replace it.
Beltman60
You know what they say, the only difference between a man and a boy is the size and cost of the toys. My son is going to be taking the JD 655 to his house in a few weeks. I cut 6+ acres between my lawn and my mother-n-law's. I always like to have a back-up tractor in case one is out of commission.
   / Hello to Tractorbynet members #10
my back up is the neighbors :laughing:
I wish I could have a back up
CASE CX330 EXCAVATOR (A52707)
CASE CX330...
ELECTRIC TRICYCLE IRET13 (A55745)
ELECTRIC TRICYCLE...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2015 FREIGHTLINER M2 24FT BOX TRUCK (A56138)
2015 FREIGHTLINER...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
